Call Control API Phone Device Not Saving
Discussion in 'CRM / Helpdesk / App Integration' started by lixid, Dec 14, 2016.
  1. lixid
    Dec 14, 2016
    5
    When I am editing the phone device for an extension or trying to create a phone device, there is no save option for that device. When I save the extension it saves the extension information but not the phone device.
    I am using the v14 version of the dll, fyi.
    Please advise on how I can do this, Thanks for your help.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi @lixid,
    Can you provide a snippet of your code editing device to see what's wrong?
  3. lixid
    Dec 14, 2016
    5
    In this example the ext will save but the new mac address does not save, and there is no Save() for the device itself.
    Also there seems to be an issue with saving in that the new name does not actually show up in the web gui under that extension until I click ok/apply under that extension. Then it propagates into the phone.
    Is there a different action for changes that are saved to actually be shown in the web gui?
    Thanks for your time on this.
    if (!String.IsNullOrEmpty(value))
    PhoneSystem.CfgServerPassword = value;
    PhoneSystem ps = PhoneSystem.Root; //Access PhoneSystem.Root to initialize ObjectModel
    string output = "";
    Extension ext = ps.GetTenants()[0].GetExtensions().SingleOrDefault(i => i.Number == "2207");
    if (ext != null)
    ext.FirstName = "Bologna999";
    PhoneDevice[] devices = ext.PhoneDevices;
    devices[0].MAC = "00156580A181";
    ext.Save();
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    I tested this code on my v15 and it worked out of the box.
  5. lixid
    Dec 14, 2016
    5
    Like I said in my first post.. the extension.FirstName saves, but the mac address does not save in v14... Can you please confirm that it saves on v14? and if so why my save does not work?
  6. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi, in v15 the MAC got saved without a problem, I will try that on v14 tomorrow and let you know.
  7. lixid
    Dec 14, 2016
    5
    Ok, thank you very much for your time on this
