Solved Call Control API - Status of extension
Discussion in 'CRM / Helpdesk / App Integration' started by Michal Knezourek, Sep 29, 2017.
  1. Michal Knezourek
    Sep 29, 2017
    9
    Hi everybody,
    I need to set status of extension via API.
    Is it possible? I don't see any functions to get and set status? by status I mean Available/Away.
    Thank you
    Michal
  2. Andreas Paradisiotis
    Apr 7, 2017
    53
    12
    Hello Michal Knezourek
    Here is an example to change the extension status using the Call Control API
    FwdProfiles[] is an array that contains the available options for presence/status
    Code:
                       var ext = PhoneSystem.Root.GetExtensions().FirstOrDefault(f => f.Number == "001");
                        if (ext != null)
                            ext.CurrentProfile = ext.FwdProfiles[3];
                            ext.Save();
    Michal Knezourek likes this.
  3. Michal Knezourek
    Sep 29, 2017
    9
    Perfect, thank you, it works great.
