Call Control API TCX.PBXAPI.OperationFailed Exception
Discussion in '3CX Phone System - General' started by Sebastian, Jun 24, 2013.
  1. Sebastian
    Jun 24, 2013
    I try to use the Call Control API. So far i was testing the OMSamples programm.
    I added the following to the 3CXPhoneSystem.ini.
    Code:
    [ConfService]
    PhoneSystem.ApplicationName = OMSamples
    and
    Code:
    [Generall]
    PBXUser=myUsername
    PBXPass=myPass
    Now my Problem is as follows:
    Every Call using the PBXConnection throws the OperationFailed Exception. I guess it has something to do with my configurations but the exception isn't very useful to determine the error. I might think it´s a common problem but i found nothing in the forums so far.
    I really would appreciate your help.
    Thanks in advance,
    Sebastian
    Edit:
    I read that the API requires a commercial license of the 3CX System. I am using a demo version, can someone confirm that this might be the Problem i'm facing ?
    Ok problem solved, it was indeed a problem with the license.
