Call Control API v15 and .Net Core on Debian
Discussion in 'CRM / Helpdesk / App Integration' started by john.wayne, Oct 2, 2017.
  1. john.wayne
    Oct 2, 2017
    I'm trying to get a .Net Core 2.0 application to work on Debian using the Call Control API v15.
    (By the way, really awesome from 3CX to provide a .Net Core compatible API :cool:)
    What does work:
    Simple .Net app (.Net Framework 4.6.2) with Call Control API v14 (3cxpscomcpp2.dll, sl.dll) on Windows
    What does not work:
    Simple .Net Core app (.Net Core 2.0) with Call Control API v15 (3cxpscomcpp2.dll) on Linux
    On starting the app I'm getting the error "Unhandled Exception: System.DllNotFoundException: Unable to load DLL 'tcxpscom_native': The specified module or one of its dependencies could not be found."
    So far so good, I've found the 3cxpscomcpp2.dll under the path /usr/lib/3cxpbx/3cxpscomcpp2.dll but were can I find the missing tcxpscom_native.dll on a Linux machine?
    Any advise would be very nice :rolleyes:
    #1 john.wayne, Oct 2, 2017
  2. Andreas Paradisiotis
    Apr 7, 2017
    53
    12
    Hello john.wayne
    You can take the Call Control API and make a new build targeting net core or net standard. Maybe you need to modify few lines of code to successfully make a build in net core.
    I'm attaching i demo project to get an idea
  3. john.wayne
    Oct 2, 2017
    This is great, thank you very much :)
