Call Coverage Keys
Discussion in '3CX Phone System - General' started by looker44, Feb 13, 2013.
  1. looker44
    Dec 31, 2012
    37
    How can I program Call coverage keys on a SPA508G to pickup a certain extension
    Example If extension 755 is ringing, I want 760 to hit a button and answer ext 755(or extension 762 to answer it)
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    You are looking to configure BLFs (Busy Lamp Fields). These are very easy to configure using the 3CX Management Console and the auto-provisioning.
    This may help: http://www.3cx.com/blog/training-videos/provisioning-plug-and-play/
  3. looker44
    Dec 31, 2012
    37
    exactly what i need to do but no exact codes do do this?
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    I didn't understand the question, please clarify.
  5. looker44
    Dec 31, 2012
    37
    yes i need to program a BLF to pickup a certain extension. I do not know where on phone interface to do this or the correct code to enter into that field
    Example If extension 755 (Name ELLEN) is ringing, I want 760 to hit a BLF button and answer ext 755
    the same will go for ext 762 to answer 755
    from the SPA508G admin guide (http://www.voipsupply.com/downloads/dl/file/id/99/cisco_spa_30x_spa_50x_spa525g_spa525g2_admin_guide.pdf (page 26)) i see general instructions
    I think my syntax on phones 760 & 762 should be
    fnc=blf+cp;sub=ELLEN@10.0.0.XX:5060;ext=755@10.0.0.XX:5060
    correct??
  6. kevin
    kevin Member
    Nov 23, 2006
    316
  7. looker44
    Dec 31, 2012
    37
    thanks - ISSUE FIXED
    For each button on the extension module (PHONE IN MY CASE), configure an extension to be monitored by setting in the "Unit 1 Key 1" field (for example) to:
    fnc=sd+blf+cp;sub=xxx@yyy.yyy.yyy.yyy;nme=xxx
    …where xxx is the extension number to be monitored, and yyy is the IP Address of the 3CX Phone System machine. So if we want a key to monitor the status of extension number 120, and the IP Address of the 3CX Phone System machine is 10.0.0.11, you should set it to:
    fnc=sd+blf+cp;sub=120@10.0.0.11;nme=120
  8. looker44
    Dec 31, 2012
    37
    When we came in this morning the provisioned phones went back to previous provisioning. How do i make it stick
    fnc=sd+blf+cp;sub=120@10.0.0.11;nme=120 on Disabled Line 4
  9. kevin
    kevin Member
    Nov 23, 2006
    316
    You need to choose whether you want to configure the phone manually, or else to use 3CX Provisioning.
    If you want to configure the phone manually, you need to remove the provisioning information from the 3CX Management Console.
    If you want to use 3CX Provisioning, and you want this custom behaviour, then you need to look into creating your own custom template file for the task.
    For details on this, ref: http://www.3cx.com/blog/voip-howto/phone-provisioning-complete-guide/
  10. looker44
    Dec 31, 2012
    37
    great. i edited XML files. thanks again
  11. looker44
    Dec 31, 2012
    37
    for the link
    there is no
    1.Go to ‘Settings’ -> ‘Phone Provisioning’ -> ‘Templates’
    I do not have a templates tab
  12. kevin
    kevin Member
    Nov 23, 2006
    316
    @looker44
    The Web-based Management Console no longer provides this possibility in V11. You can customise your templates directly from the filesystem, using, for example, Notepad++ as your editor.
    Template files you would find in:
    C:\ProgramData\3CX\Data\Http\Templates\phones
  13. looker44
    Dec 31, 2012
    37
    thanks.
    when i originally fixed this, I edited the MACaddress.xml for my two extensions to cover the other extension (in this dir C:\ProgramData\3CX\Data\Http\Interface\provisioning) . the problem came when we did windows update and reboot. all the MACAddress.xml files were rebuilt.
    So now I have copied the cisco_sidecarSPA50X.ph.xml to a file named cisco_sidecarSPA50X_YX.ph.xml and edited my blf keys as needed.
    how do i associate in 3cx that template to those mac address
    FOUND VIDEO WILL TRY IT
    thx
  14. looker44
    Dec 31, 2012
    37
    my template edits do not work
    How can i just NOT have 3cx manage provisioning these two phones. I have tried removing the mac address from the provisioning screen. it keeps saying please enter valid mac address
  15. kevin
    kevin Member
    Nov 23, 2006
    316
    @looker44
    Remove the MAC Address and ALSO the Phone Model.
  16. looker44
    Dec 31, 2012
    37
    thank you
    Should I also remove the provisioning line in the phones gui?
  17. looker44
    Dec 31, 2012
    37
    THX
    should I also set the Provision Enable to NO in the phones GUI? or remove the profile rule line?
  18. kevin
    kevin Member
    Nov 23, 2006
    316
    @looker44
    Yes, you can remove it, won't hurt.
