Call disconnect at pickup
Discussion in '3CX Phone System - General' started by bascons, May 21, 2010.
  1. bascons
    May 21, 2010
    Dear all,
    Whenever someone calls our main number and the receptionist picks up the phone the call is disconnected directly. Further more does this only happen to anonymous calls.
    Log file entry:
    Code:
    13:18:01.171|.\CallCtrl.cpp(161)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(1619): Incoming call from anonymous@(Ln.10002@ISDN) to <sip:20@192.168.1.50:5060><br>
    13:18:01.171|.\CallCtrl.cpp(446)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(1619): Route 1: Ext:Ext.20@[Dev:sip:20@192.168.1.156:2048;line=l4530lv4]<br>
    13:18:01.203|.\Target.cpp(430)|Log2||Target::makeOneInvite:[CM503025]: Call(1619): Calling Ext:Ext.20@[Dev:sip:20@192.168.1.156:2048;line=l4530lv4]<br>
    13:18:06.875|.\Call.cpp(1015)|Log2||Call::Terminate:[CM503008]: Call(1619): Call is terminated<br>
    10,360
    226
    Did this just start recently? What type (make/model) gateway are you using?
