Call diversion to external line
Discussion in '3CX Phone System - General' started by klawrence, Oct 29, 2007.
  1. klawrence
    Oct 23, 2007
    10
    Prior to using 3CX, we would have enabled call diversion on our PSTN line simply by dialling *21* 0777123456 from the handset which would divert phone calls to a company mobile when we were out of the office.
    I have tried the same function by dialling 9 *21*0777123456 on our new voip handset (we use 9 for outside line) but the call wont go through and i get an error tone which is coming from our SPA3102.
    I have a feeling this is due to the dial plan for Line 1 on the SPA. The current plan is (*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.).
    I honestly find it very hard to make any sense of dial plans!
    Can someone advise how I can alter the dial plan to allow *21* to work?
    Alternatively, is it possible to divert incoming calls to a mobile phone within 3CX itself?
    This is a great forum community. Thanks in advance!
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I have that very same problem, since SPA3102 uses * has a special character to make transfers, and so on, when you dial that you will be telling the SPA to do the thing that he has set has *21 wich if im not wrong is nothing....
    i tried to change this codes for 3 digit numbers, by simple adding a "x" on the dial plan on "*xx" also tried to add some other things to the dial plan and i managed to sucessfully make it working, the thing is, it would only work 1 time.. lol, i changed the dial plan, and after that, i managed to make it work...but just one time lol, after this time i couldnt make any more calls. What i add in this case was before the ")" |*200:*200
    This dial plan was used to say that whenever i dialed *200 he would make the call *200, you can try and change this to |*21*xxxxxxxx:*21*xxxxxxxxx
    Use has many x's has your phone numbers have there...
    Cheers
  3. nmangaoang
    Jun 22, 2007
    35
    Why not use call forwarding on the extension. Forward All Calls > Forward to outside number.
    Regards,
    Nick
  4. klawrence
    Oct 23, 2007
    10
    That works fine too but its really a question of convenience. Its much quicker when leaving the office to dial 9*21*0777123456 on a handset than have to log into the web ui and change the extension options.
    Anyone else found a resolution?
  5. klawrence
    Oct 23, 2007
    10
    problem resolved
    I can set divert all calls from the SPA922 interface so everything is grand now!
    Thanks for the replies
