call drops after 15 mins
Discussion in '3CX Phone System - General' started by jmatson, May 16, 2011.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    I just upgraded to V10. had no problems before. and now after 15:31 the calls drops. it happened 3 mins today.
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Can you provide:
    What type of handset you are using
    Are you using a PSTN gateway or VOIP provider and which one
    Set your logging to verbose and post that as well showing the the call failing, removing any external IP addresses and phone numbers
    There are not any reports of this type of error during the testing of V10. So the log could reveal the cause of your issue?
  3. felixg
    May 23, 2011
    I'm having almost the same issue. After 15:30 minutes into the call the audio disappears. The call is not terminated, but no side hears the other. The logs continue to show that call is active.
    I'm using 3CX V9 SP5a on a VOIP provider (Israeli 073 NetVision). I've set:
    Supports Re-Invite: true
    Supports 'Replace': false
    PBX Delivers Audio: false
    Do not require registration
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    763
    39
    Does this problem occur recently?
    Is in 3CX STUN enabled?
    Default VoIP provider settings are:
    Supports Re-Invite: false
    PBX Delivers Audio: true
    Require registration for: In and Outgoing Call
  5. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    next time i have a call that's that long i will get the logs.
  6. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Try enabling Keep Alives
    >> Settings > General Settings > Global Options (Enable Keep Alives)
    test and confirm if this helps?
