Call drops immediately after transfer
Discussion in '3CX Phone System - General' started by sanyaolu, Jun 22, 2008.
  1. sanyaolu
    Apr 5, 2008
    10
    Does any on have a solution to Call drops immediately after transfer. The big picture is that i use the Digital Receptionist / Auto attendant to farward calls to an extension. That extension is configured to forward to my cell if it is unregistered. It workes okay however as soon as the call is transfered to my cell phone and i pick it the call drops within like 2 secs.
    I guess it has to do with blind or monitor transfer. Can someone help ?
    Adeolu
  2. sanyaolu
    Apr 5, 2008
    10
    The config for extension 1010 is as follows;
    The log is as follows
    Code:
    Time Function Message
    20:18:28.328 Call::Terminate [CM503008]: Call(21): Call is terminated
    20:18:28.031 Call::Terminate [CM503008]: Call(21): Call is terminated
    20:18:27.875 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:8501
    20:17:55.156 Call::Terminate [CM503008]: Call(23): Call is terminated
    20:17:54.921 Call::RouteFailed [CM503015]: Call(23): Attempt to reach [sip:8001@127.0.0.1:5060] failed. Reason: Not Registered
    20:17:54.812 Call::RouteFailed [CM503015]: Call(23): Attempt to reach [sip:8001@127.0.0.1:5060] failed. Reason: Not Registered
    20:17:54.812 CallCtrl::onSelectRouteReq [CM503016]: Call(23): Target is not registered: HuntGrp8001:1010Ext.1010
    20:17:54.781 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:8001@127.0.0.1:5060]
    20:17:54.562 CallCtrl::onIncomingCall [CM503001]: Call(23): Incoming call from Ext.8501 to [sip:8001@127.0.0.1:5060]
    20:17:54.531 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:8001@127.0.0.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-43055813cd3fb008-1---d8754z-;rport=40600
    Max-Forwards: 70
    Contact: [sip:8501@127.0.0.1:40600]
    To: [sip:8001@127.0.0.1:5060]
    From: "905515xxxx"[sip:905515xxxx@127.0.0.1:5060];tag=6628f977
    Call-ID: MzhmZWNkN2FlODQxZWRjMjI4MjQyZjQ1ZjllMGYwYzg.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Proxy-Authorization: Digest username="8501",realm="3CXPhoneSystem",nonce="12858653874:1a423d95131ecfb6f3f57a1963bc36dc",uri="sip:8001@127.0.0.1:5060",response="e271c9fd7829a32f3e8dd59c0b720114",algorithm=MD5
    Supported: replaces
    User-Agent: 3CX IVR
    Content-Length: 0
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Calls from ring group to extensions ARE NOT forwarded on ANY CONDITIONS!
    I suppose we need to state it somewhere on the first page of user's manual with capital letters...
  4. sanyaolu
    Apr 5, 2008
    10
    Thanks Archie for the info. However i did not see it in the manual...... Is it something you guys are considering adding in future ?
    Now the issue remains even when an outside caller calls the 3CX PBX Digital Receptionist / Auto attendant which forward calls to an internal extension and the call dropps immediately after the transfer. What is your view on this ? Please see logs below.
    Code:
    18:10:33.875	Call::Terminate	[CM503008]: Call(47): Call is terminated
    18:10:33.671	Call::Terminate	[CM503008]: Call(47): Call is terminated
    18:10:32.171	Call::Terminate	[CM503008]: Call(49): Call is terminated
    18:10:31.937	Call::Terminate	[CM503008]: Call(49): Call is terminated
    18:10:31.828	LineCfg::getInboundTarget	[CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:8501
    18:10:31.593	MediaServerReporting::SetRemoteParty	[MS210002] C:48.1:Offer provided. Connection(transcoding mode): 64.228.219.126:9010(9011)
    18:10:30.937	MediaServerReporting::SetRemoteParty	[MS210001] C:49.2:Answer received. RTP connection: 172.26.1.4:5004(5005)
    18:10:30.921	CallLeg::setRemoteSdp	Remote SDP is set for legC:49.2
    18:10:30.546	Call::Terminate	[CM503008]: Call(48): Call is terminated
    18:10:30.062	MediaServerReporting::SetRemoteParty	[MS210002] C:49.2:Offer provided. Connection(transcoding mode): 172.26.1.2:7118(7119)
    18:10:30.062	Call::Terminate	[CM503008]: Call(48): Call is terminated
    18:10:30.046	LineCfg::getInboundTarget	[CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:8501
    18:10:29.812	LineCfg::getInboundTarget	[CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:8501
    18:10:29.765	CallLeg::onRefer	Relpaces: ZTQ5ZTdlNTUxMWZmNzc3Y2I4ODc0MDhlN2RmMDUwNmM.;to-tag=cf3ea360;from-tag=113b860f
    18:10:29.765	CallLeg::onRefer	Refer: from="9055555555"[sip:9055555555@127.0.0.1:5060];tag=7c29d564; to=[sip:1002@127.0.0.1:5060];tag=28281264; RefTo="9055555555"[sip:9055555555@sanyaolu.dlinkddns.com:5060?Replaces=ZTQ5ZTdlNTUxMWZmNzc3Y2I4ODc0MDhlN2RmMDUwNmM.%3Bto-tag%3Dcf3ea360%3Bfrom-tag%3D113b860f];tag=cf3ea360
    18:10:29.687	CallLeg::onConfirmed	Session 3420 of leg C:49.1 is confirmed
    18:10:29.531	CallCtrl::onLegConnected	[CM503007]: Call(49): Device joined: sip:1002@172.26.1.4:5060;transport=udp
    18:10:29.484	MediaServerReporting::SetRemoteParty	[MS210001] C:49.2:Answer received. RTP connection: 172.26.1.4:5004(5005)
    18:10:29.484	CallLeg::setRemoteSdp	Remote SDP is set for legC:49.2
    18:10:24.265	Extension::printEndpointInfo	[CM505001]: Ext.1002: Device info: Device Identified: [Man: GrandStream;Mod: GXP-2000;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.6.16] Transport: [sip:172.26.1.2:5060]
    18:10:24.265	CallCtrl::onAnsweredCall	[CM503002]: Call(49): Alerting sip:1002@172.26.1.4:5060;transport=udp
    18:10:24.031	MediaServerReporting::SetRemoteParty	[MS210002] C:49.2:Offer provided. Connection(transcoding mode): 172.26.1.2:7118(7119)
    18:10:23.718	CallCtrl::onSelectRouteReq	[CM503004]: Call(49): Calling: Ext:Ext.1002@[Dev:sip:1002@172.26.1.4:5060;transport=udp]
    18:10:23.718	CallCtrl::onSelectRouteReq	[CM503010]: Making route(s) to [sip:1002@127.0.0.1:5060]
    18:10:23.515	CallCtrl::onIncomingCall	[CM503001]: Call(49): Incoming call from Ext.8501 to [sip:1002@127.0.0.1:5060]
    18:10:23.500	CallLeg::onNewCall	[CM500002]: Info on incoming INVITE:
    INVITE sip:1002@127.0.0.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-5d2a89753e798873-1---d8754z-;rport=40600
    Max-Forwards: 70
    To: [sip:1002@127.0.0.1:5060]
    From: "9055555555"[sip:9055555555@127.0.0.1:5060];tag=7c29d564
    Call-ID: MzVhYzE3Mjg4YTllMWEzY2UxMDJmNTFjMzFkMWQ5NWY.
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="8501",realm="3CXPhoneSystem",nonce="12858732623:eb25cdb0801a5d97bb277f97fe276297",uri="sip:1002@127.0.0.1:5060",response="5031d74c603624503ae79b71b111024f",algorithm=MD5
    Supported: replaces
    User-Agent: 3CX IVR
    Content-Length: 0
    18:10:05.843	CallLeg::onConfirmed	Session 3414 of leg C:48.1 is confirmed
    18:10:05.484	CallCtrl::onLegConnected	[CM503007]: Call(48): Device joined: sip:8501@127.0.0.1:40600;rinstance=342b6d7fef162657
    18:10:05.484	LineCfg::getInboundTarget	[CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:8501
    18:10:05.359	CallCtrl::onLegConnected	[CM503007]: Call(48): Device joined: sip:9055555555@194.221.62.198:5060
    18:10:05.359	MediaServerReporting::SetRemoteParty	[MS210003] C:48.1:Answer provided. Connection(transcoding mode):64.228.219.126:9010(9011)
    18:10:05.359	MediaServerReporting::SetRemoteParty	[MS210001] C:48.2:Answer received. RTP connection: 127.0.0.1:40642(40643)
    18:10:05.328	CallLeg::setRemoteSdp	Remote SDP is set for legC:48.2
    18:10:05.265	Extension::printEndpointInfo	[CM505001]: Ext.8501: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] Transport: [sip:127.0.0.1:5060]
    18:10:05.265	CallCtrl::onAnsweredCall	[CM503002]: Call(48): Alerting sip:8501@127.0.0.1:40600;rinstance=342b6d7fef162657
    18:10:04.703	MediaServerReporting::SetRemoteParty	[MS210002] C:48.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7116(7117)
    18:10:04.281	CallCtrl::onSelectRouteReq	[CM503004]: Call(48): Calling: Ext:Ext.8501@[Dev:sip:8501@127.0.0.1:40600;rinstance=342b6d7fef162657]
    18:10:04.265	CallCtrl::onSelectRouteReq	[CM503010]: Making route(s) to [sip:8501@sanyaolu.dlinkddns.com:5060]
    18:10:04.265	MediaServerReporting::SetRemoteParty	[MS210000] C:48.1:Offer received. RTP connection: 194.120.0.10:11782(11783)
    18:10:04.265	CallLeg::setRemoteSdp	Remote SDP is set for legC:48.1
    18:10:04.265	Line::printEndpointInfo	[CM505003]: Provider:[CECMISS01VoIPCheap] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [(Very nice Sip Registrar/Proxy Server)] Transport: [sip:172.26.1.2:5060]
    18:10:04.265	LineCfg::getInboundTarget	[CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:8501
    18:10:04.031	CallCtrl::onIncomingCall	[CM503001]: Call(48): Incoming call from 9055555555@(Ln.10002@CECMISS01VoIPCheap) to [sip:8501@sanyaolu.dlinkddns.com:5060]
    18:10:03.750	LineCfg::getInboundTarget	[CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:8501
    18:10:03.625	CallLeg::onNewCall	[CM500002]: Info on incoming INVITE:
    INVITE sip:cecmiss1@64.228.216.11:5060;rinstance=8a388e5cec44e020 SIP/2.0
    Via: SIP/2.0/UDP 194.221.62.198:5060;branch=z9hG4bK4f4f5f9400654bdd9afcfc6a5e528a06
    Contact: [sip:9055555555@194.221.62.198:5060]
    To: [sip:cecmiss1@64.228.216.11:5060]
    From: "9055555555"[sip:9055555555@sip.voipcheap.com:5060];tag=cf1710accf2b10ac485f92b42b271
    Call-ID: 9b72235913944d7291578c6a9ce75727@194.221.62.198
    CSeq: 4 INVITE
    Allow: ACKBYE, CANCEL, INVITE, REGISTER, OPTIONS, INFO, MESSAGE
    User-Agent: (Very nice Sip Registrar/Proxy Server)
    Content-Length: 0
    18:09:59.187	CallCtrl::onLegConnected	[CM503007]: Call(47): Device joined: sip:10001@172.26.1.3:5061
    18:09:59.109	CallLeg::onConfirmed	Session 3408 of leg C:47.1 is confirmed
    18:09:59.015	CallCtrl::onLegConnected	[CM503007]: Call(47): Device joined: sip:1001@172.26.1.3:5060
    18:09:58.937	MediaServerReporting::SetRemoteParty	[MS210007] C:47.1:Answer provided. Connection(by pass mode): 172.26.1.3:16454(16455)
    18:09:58.921	MediaServerReporting::SetRemoteParty	[MS210001] C:47.2:Answer received. RTP connection: 172.26.1.3:16454(16455)
    18:09:58.796	Line::printEndpointInfo	[CM505002]: Gateway:[VoiceCheap01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-3.3.6(GW)] Transport: [sip:172.26.1.2:5060]
    18:09:58.796	CallCtrl::onAnsweredCall	[CM503002]: Call(47): Alerting sip:10001@172.26.1.3:5061
    18:09:58.781	CallLeg::setRemoteSdp	Remote SDP is set for legC:47.2
    18:09:58.625	CallCtrl::onSelectRouteReq	[CM503004]: Call(47): Calling: VoIPline:0012888888888@(Ln.10000@VoiceCheap)@[Dev:sip:sanyaolua@sip.VoipCheap.com:5060]
    18:09:58.609	MediaServerReporting::SetRemoteParty	[MS210006] C:47.2:Offer provided. Connection(by pass mode): 172.26.1.3:16452(16453)
    18:09:58.375	MediaServerReporting::SetRemoteParty	[MS210000] C:47.1:Offer received. RTP connection: 172.26.1.3:16452(16453)
    18:09:58.312	CallCtrl::onSelectRouteReq	[CM503004]: Call(47): Calling: PSTNline:2888888888@(Ln.10001@VoiceCheap01)@[Dev:sip:10001@172.26.1.3:5061]
    18:09:58.296	CallCtrl::onSelectRouteReq	[CM503010]: Making route(s) to [sip:2888888888@172.26.1.2]
    18:09:58.187	CallLeg::setRemoteSdp	Remote SDP is set for legC:47.1
    18:09:58.187	Extension::printEndpointInfo	[CM505001]: Ext.1001: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-3.3.6(GW)] Transport: [sip:172.26.1.2:5060]
    18:09:58.000	CallCtrl::onIncomingCall	[CM503001]: Call(47): Incoming call from Ext.1001 to [sip:2888888888@172.26.1.2]
    18:09:57.812	CallLeg::onNewCall	[CM500002]: Info on incoming INVITE:
    INVITE sip:2888888888@172.26.1.2 SIP/2.0
    Via: SIP/2.0/UDP 172.26.1.3:5060;branch=z9hG4bK-89ebbe5
    Max-Forwards: 70
    Contact: "Ade"[sip:1001@172.26.1.3:5060]
    To: [sip:2888888888@172.26.1.2]
    From: "Ade"[sip:1001@172.26.1.2];tag=decff86a6b647045o0
    Call-ID: 738ed30e-2710b5f1@172.26.1.3
    CSeq: 102 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Proxy-Authorization: Digest username="1001",realm="3CXPhoneSystem",nonce="12858732597:3dbff09325d05dd2ba1f2397ef9206b2",uri="sip:2888888888@172.26.1.2",algorithm=MD5,response="de4e94a5ff496b353b4e25f58ce3057a"
    Supported: x-sipura
    User-Agent: Linksys/SPA3102-3.3.6(GW)
    Content-Length: 0
    Remote-Party-ID: Ade [sip:1001@172.26.1.2];screen=yes;party=calling
  5. archie
    3CX Support
    Aug 18, 2006
    1,299
    Try to untick "support re-invite's" for your provider.
  6. sanyaolu
    Apr 5, 2008
    10
    Hi Archi,
    I did untick "support re-invite's" for provider. Not did it only solve the call from Cell phone via 3CX PBX Digital Receptionist / Auto attendant to an internal extension. It also resolves my inertial problem.
    Now A PSTN phone can call my 3CX PBX Digital Receptionist / Auto attendant which forward calls to an internal "unregistered" extension which then forwards it out to a cell phone(PSTN) and the connection established with out dropping off like before.
    Adeolu
