Call duration
Discussion in '3CX Phone System - General' started by mixig, Oct 22, 2012.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    by default (in v11) is there any time limit for local and outbound call durations? Can it be configured with own time value?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    In V11, the default call duration is 3 hours after which it should drop the call. The variable is found in the advanced settings, custom parameters, MAXCALLDURATION. There is no way that 3CX understands the various call strings to know if local, internal, long distance or international as there is no place by which to define each. It is simply a string of numbers that we have defined to be handled in a certain manner on the outbound or as internal extension, so all are treated as the same.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Nice,
    i found in the call reporting that some calls were disconnected after 179:xx minutes so i assumed that there is some limit (3 hours), thanks for the reply.
