Call ends after 30 sec
Discussion in '3CX Phone System - General' started by Anonymous, Nov 24, 2006.
  1. Anonymous
    Anonymous Guest
    I have the beta 3 installed and any call after 20 secs i hear the sound distorsioned and after other 10 sec i hear nothing but hte conection remains active until i hang up.
    Can anyone help me on that?
    Thnx
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    Disconnection
    Can you try to restart the machine and see if the problem continues? Is this for all calls, including internal, or only gateway and / or VOIP providers.
  3. Anonymous
    Anonymous Guest
    I restarted the machine and the problem continues.
    The problem is for all calls including internal.
  4. Anonymous
    Anonymous Guest
    I tried to use sofware phones and hardware phones, the problem is the same for all tipe of calls :roll:
    I read all the documentation and i'm sure i respected all the indications but i still can't solve this problem.
  5. Anonymous
    Anonymous Guest
    Here are some logs from 3cx media server
    can this be the problem?
    14:27:58.953|MSEndPoint.cpp(505)|Error1||??: EP:0000001E@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:58.968|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:58.984|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.000|MSEndPoint.cpp(505)|Error1||??: EP:0000001E@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.000|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.015|MSEndPoint.cpp(505)|Error1||??: EP:0000001E@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.015|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.031|MSEndPoint.cpp(505)|Error1||??: EP:0000001E@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.046|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.062|MSEndPoint.cpp(505)|Error1||??: EP:0000001E@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.062|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.078|MSEndPoint.cpp(505)|Error1||??: EP:0000001E@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.078|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.093|MSEndPoint.cpp(505)|Error1||??: EP:0000001E@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.093|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.109|MSEndPoint.cpp(505)|Error1||??: EP:0000001E@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.125|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.140|MSEndPoint.cpp(505)|Error1||??: EP:0000001D@192.168.1.159Possible mistiming of RTP stream. RTPPacket timestamp is less then expected
    14:27:59.140|MediaServer.cpp(600)|Log2||??: EndPoint 0000001D@192.168.1.159 removed from call 0000000E
    14:27:59.140|MediaServer.cpp(637)|Log2||??: EndPoint 0000001E@192.168.1.159 removed from call 0000000E
    14:27:59.171|MediaServer.cpp(376)|Log2||??: references to EndPoint 0000001E@192.168.1.159 were removed
    14:27:59.171|MediaServer.cpp(665)|Log2||??: references to call 0000000E were removed
    14:27:59.171|MSCallConf.cpp(30)|Log2||??: Call: 0000000E destroyed
    14:27:59.187|MediaServer.cpp(376)|Log2||??: references to EndPoint 0000001D@192.168.1.159 were removed
  6. Nick Galea
    Jun 6, 2006
    1,994
    306
    working on it
    hi there,
    thanks for this. we are familiar with this problem and trying to resolve the matter now.
