Call failed; Not found
Discussion in 'Android' started by styles, Dec 31, 2017.
  1. styles
    Dec 31, 2017
    I can make outbound calls from the web portal fine. I can't make them from the android phone. I receive "Call failed; Not found from the app. In the management portal the only log that's generated is
    ```Extension 000 is registered, contact: sip:000@10.134.240.95:50195;transport=TCP;rinstance=1-;ob;inst="xxx"```
    How can I debug this further?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @styles
    Is the issue only with outbound calls? Can you receive calls and call other extensions from the android client? If so the first thing you need to check is your outbound rules and if the call matches any of the outbound rules you have created.
