Call fails with "Cause: 302 Moved Temporarily"
Discussion in '3CX Phone System - General' started by kiliev, Feb 15, 2011.
  1. kiliev
    Feb 15, 2011
    5
    Hi Team,
    I am experiencing the following situation. I am calling some number (over a SIP Trunk) and call fails. The logged event is as follows:
    > Call(1790): Call to sip:XXXXX@87.227.149.XXX:5060 has failed;
    > Cause: 302 Moved Temporarily; from IP:87.227.149.XXX:5060
    The provider support is telling me that in the Temporarily Moved message contact header they are providing the correct number to be dialed and they are expecting the 3cx on my side to send another invite using the provided contact.
    They assumed i am using asterix and provided me with the following guidance:
    In sip.conf add the line promiscredir=yes
    Is this possible in the 3cx world? Any guidance?
    Thanks in advance.
    Best regards,
    K
  2. kiliev
    Feb 15, 2011
    5
    Resolved.
    Upgrade to version 9.
    Then make the provider form the redirect like number@3cx-ext-ip-address and it all worked. <-this was nessesry as with the number formed like number@provider-ip the 3cx was unable to route the call.
    cheers,
    K
  3. PaulGarcia
    Aug 6, 2014
    8
    There has to be some interaction as...
    ...it works when I do an internal redirect..e.g...on NO ANSWER, redirect on the Cisco phone. i.e. EXTERNAL CALL IN => x201, NO ANSWER then CALL x200, it works!
    However when I try an external number on the cisco phone redircet. i.e..... EXTERNAL CALL IN => x201, NO ANSWER then CALL external number, it does not work. Server log ultimatly says...302 Mo0ved Temporarily.
    It starts a new leg ok so is picking up the number, and gets to....
    Contact: <sip:xxxxxxxxxx@10.56.24.10:5060> (where xxxxxxxxxx is the corrcet external number.)
    and then the error as the external number is not on our 3CX, so fails.
    Looking at the similar fault codes from previous versions on 3CX on this forum. It looks like the IP in this Contact sould be the provider IP.
    Any ideas where I can change this? Any other suggestions?
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    I guess the question becomes why are you trying to redirect from the phone itself rather than the PBX? You are correct in you assessment in that 3CX is indeed the SIP server and the phone is trying to direct the call, but due to it using an internal address the system is looking internally.
