Call Flow at end
Discussion in 'Call Flow Designer' started by Tomas Raska, Oct 4, 2017.
  1. Tomas Raska
    Aug 18, 2017
    58
    6
    Hello, Voice Apps are located in 3cx / Queues.
    When I create new Voice App in Call Flow Designer and activate in 3cx, then I have this Problem:
    How can I return from VoiceApp back to queue?
    I have in VoiceApp some conditions, and when every condition is "FALSE", then I need return to Queue, but now call is ended.
    Is it necessary to create new Queue? And in VoiceApp at end transfer calls to this new Queue?
    Thank you
    rsuren likes this.
  2. rsuren
    Sep 21, 2017
    39
    5
    i have same question, like i want to save all the phone numbers coming to this queue using web service and than continue to this queue normal flow like agents phone ringing
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,351
    108
    CFD queues are special queues, without agents, and every call that arrives to them will be taken by the CFD and not processed by the queue. So if you need a normal queue with agents, then you need 2 different queues, one for the CFD app and other for the agents. Then, when you decide it in your app, you transfer the call from the CFD app to the normal queue.
    Kind regards.
