Call Flow Debugging
Discussion in 'Ideas' started by fber, Aug 21, 2017.
  1. fber
    Mar 7, 2017
    As described in Call Flow debugging for Queue the call flow debugging is rather limited. In other PBX systems calls are represented as a combination of call-legs. A call consists of a call-leg from the caller to the PBX and a call-leg from the PBX to the current agent. By uniquely identifying call-legs instead of a whole call it would be possible to precisely reconstruct the call flow.
