Call Flow Designer - Dynamic Audio file
Discussion in 'Call Flow Designer' started by imagemaster, May 28, 2017.
  1. imagemaster
    Jul 20, 2010
    46
    I have created a folder, put the wav file in that folder and the absolute file in the Prompt Collection Editor:
    CONCATENATE("/var/lib/3cxpbx/Instance1/Data/RS_Audio/",userInputComponent1.Buffer,".wav")
    output: /var/lib/3cxpbx/Instance1/Data/RS_Audio/71451.wav
    It fails. Also, can it play an mp3 instead of a wav?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,600
    125
    Hi @imagemaster,
    Please note that wav files must be in the supported format, as described here:
    https://www.3cx.com/docs/converting-wav-file/
    If your wav files have a different format, they will be ignored. Also mp3 files can't be used. Please check the format and let us know.
    Kind regards.
