Call Flow Designer vs. basic configuration
Discussion in 'Call Flow Designer' started by Scot Busby, Jun 20, 2017.
  1. Scot Busby
    Jun 8, 2017
    18
    This could be a silly question, however, I have a basic auto attendant setup flowing to several call queues and voicemail boxes and was looking at Call Flow Designer to help with the design. In trying to learn about this tool and comparing to how I seem to be able to easily setup this kind of thing without using the tool, I am curious as to the advantages of using this tool rather than just setting up this configuration in the system.
    I understand how this tool can be used in complex environments, however since my environment is relatively simple, wondered if I am missing something.
    Thank you!
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,078
    76
    Hi @Scot Busby,
    For such a simple flow, using standard Digital Receptionists in the system might be a good solution as well. It's up to you, if you feel more comfortable following a way or the other...
    Kind regards.
  3. Scot Busby
    Jun 8, 2017
    18
    Hi @edossantos
    Thank you for the information. More specifically, are there advantages to using this tool over building in the system?
    Thank you,
    Scot
  4. edossantos
    Jun 27, 2007
    1,078
    76
    Hi Scot,
    Using the CFD you have a more friendly view of the callflow. You see a diagram with blocks connected, and you easily see what happens when a user presses an option. I think it's easier to draw the callflow using the CFD than building it with DRs in the system.
    However, there are some things to consider:
    - If you need to make a change, you need to redeploy the app. In the CFD that means restarting the queue manager service, dropping all active calls on any queue.
    - You don't have built in functions like call by name. If you need them you better do it with DRs.
    Hope the information helps you to make a decision.
    Kind regards.
    VictorSP likes this.
