Call forwarding and voicemail
Discussion in '3CX Phone System - General' started by netswork, Apr 11, 2012.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    My customer asked me a question I did not know the answer to, I tested it and could not do what they asked. Perhaps someone knows a way.
    With cisco callmanager if I set my phone to forward to my assistant if I dont answer or my phone is busy...and my assistant does not answer the phone and it goes to her voicemail...the call actually goes back to my voicemail box.
    I tested this by forwarding my phone no answer to another extension... that extension was set to forward no answer to voicemail. Rather than it coming back to my voicemail, which was the originally dialed extension, it went into the other phones voicemail box. Is there any way to do this with 3cx?
  2. albertc
    Nov 21, 2011
    89
    Yes, you can create a ring group "Assistant" and put your assistant's ext into it. Than define the forwarding rule on your ext so when your phone is busy / no answer, it'll go to that ring group. And configure the forwarding rule on that ring group "assistant" to send call to your voice mail box if no answer. So, when a call comes in to your ext and no answer/busy, it'll go to the ring group. Your assistant ext ring. And if no answer, it'll go back to your voice mail.
  3. netswork
    Mar 11, 2011
    577
    Thanks for your reply. That sounds like a good work around. I might make a ideas request for that feature to be similar to what I have seen in other systems.
    Thanks again for your help
