Call forwarding is not working
Discussion in '3CX Phone System - General' started by Dark One, Jan 8, 2008.
  1. Dark One
    Dec 11, 2007
    9
    I have a 3CX server and some linksys spa-922 phones and i am using musimi as provider.
    When calling an internal extention, forwarding works as intended, but.
    If i answer an incoming call (or call out) and try to transfer, it will hang up the call...
    Any ideas ?
    I have configured musimi as a generic SIP, and phones are configured as written in the howto on 3cx website.
    -Frank
  2. Dark One
    Dec 11, 2007
    9
    Can i assume that free version can only handle internal extention forwarding ???
  3. simones181170
    Dec 4, 2007
    51
    i've same problem with Linksys PAP2
    with my ip phone the call trasfer works well but no way with linksys
  4. Dark One
    Dec 11, 2007
    9
    Well now it works... Kinda
    On internal calls, it works flawlessly... but on external call, when transfered to another internal extention this happens...
    I receive call.. pres x-fer and dial new extention. Extention answers.. and then after approx. 20-25 sec the xfer button comes back, and i can complete the transfer.... What can be the reason for this delay ? it is not on internal transfers, they work immidiately.
    -Frank
  5. Dark One
    Dec 11, 2007
    9
    Im willing to pay for the solution :)
    I really need this up and running in a hurry...
  6. Molsen6
    Mar 14, 2007
    32
    Hi Dark one
    I have seen the same on spa962. I went back on the firmware on the spa.
    Then it works
    Maybe the same on spa922
  7. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    What firmware are you using?
    I have SPA942s and the xfer button does seem to take a couple seconds to show up after dialing.
    I don't think this is 3CX related but maybe is? Does 3CX send info to the phone for status changes?
  8. Dark One
    Dec 11, 2007
    9
    Simones what firmware did u roll back to ?
    -Frank
  9. caojun76
    Jan 14, 2008
    6
    I am also facing for the same problem with ATA of Handytone 386, 286, SPA 200, and PAP2 etc.
    Any body can give the solution for this?
  10. simones181170
    Dec 4, 2007
    51
    Software Version 3.1.15(LS)
    now it works
    with the new swetting
    Hook Flash Timer Min: 0,06
    Hook Flash Timer Max: 0,2
  11. caojun76
    Jan 14, 2008
    6
    Is there anyone have successed for the call forwarding by the ATA of PAP2 or Sipura 2000?
