Call Forwarding Out of Office Hours
Discussion in '3CX Phone System - General' started by sbozzy, Aug 1, 2011.
  1. sbozzy
    Oct 21, 2010
    I am using v10 SP2 of the 3CX Phone System and am having an issue when it comes to routing of calls to my mobile after hours.
    The system consists of 3 Yealink IP Phones, 1 T28P and 2 T22P and 2 x SPA3102s for the PSTN lines, there are no VOIP accounts. Eash SPA has a line assigned to it, Line 1 and Line 2. The problem I am having is that when there is an incoming call on Line 1 and it is out of office hours, the call gets routed to my mobile via Line 2, but when somebody calls on Line 2, the call does not get routed to my mobile via Line 1.
    What could be the issue with the routing?
    10,767
    286
    Off hand, I would say it is something in your outbound rules (trunk order?). Have a look at, or post, the 3CX server Log of each type of call. You should be able to compare and see where the failure is occurring. You can then make changes to allow the call to complete.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    It is not possible to route the call back on the same analog line, unless the provider supports this. That's why the call is forwarded on the other line, this is pretty normal.
    Most PSTN providers use codes like this:
    *21*number# - forward all calls; *21# - cancel
    *61*number# - forward N/A; *61# - cancel
    *67*number# - forward busy; *67# - cancel
    Check these codes with your provider, whether applicable.
    Mind sending such command to provider may need special programming of your SPA-3102 (dial plan).
    Regards
  4. sbozzy
    Oct 21, 2010
    I am attaching logs of both types of call forwards.
    I activate call-forwarding on my extension 101 when I leave the office to my mobile. This extension is also part of a ring group 800. Could this be causing the problem?
    Any help would be much appreciated.
  5. willow
    willow Member
    Mar 1, 2011
    471
    13:30:19.217 [CM303003]: There are no available outbound lines on gateway 021-552-0888 at this time.
    this is your issue? how are your pstn gateways setup? are they 2 devices or just one? make sure your outbound rules for dialing your mobile have both gateway devices in it.
