Call forwarding to external number
Discussion in '3CX Phone System - General' started by giosonline, Aug 29, 2009.
  1. giosonline
    Aug 28, 2009
    I am pretty new to the 3CX system and slowly learning but loving it. I am currently evaluating the system with the free edition I downloaded. It is running in a Windows 2003 server and I used the Cassini option for webserver. I have two DIDs / sip trunks with the capacity of 5 simultaneous calls. I am using the 3CX softphones in the laptops and have two Linksys SPA941 sip phones on our desks.
    Based on what I've read I should be able to transfer or forward calls to an external number such as a mobile / cellphone. I can do internal transfer or forwards to extensions but not external numbers. Is this a limitation within the Free edition? or am I simply misconfiguring something?
    Any ideas or comments?
    Many thanks!
    Luis
  2. meshad
    Aug 5, 2009
    41
    to transfer or forward calls to an external number such as a mobile / cellphone. you need have PSTN VOIP Gateway and it is possible with free edition also
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    You can forward calls using a PSTN gateway or also a VOIP provider, so if you are having problems it may be the way you have the SIP trunk set up.
  4. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    If you have setup in your dialplan to dial a prefix before the number like, 9, then you have to include that in your external forward number.
  5. giosonline
    Aug 28, 2009
    We do not dial any line access code. We simply choose the line and dial the standard number.
    Should I place a screenshot of the configuration? If so, what should I post to see if I have configured the trunks improperly?
    Thanks all for the responses and suggestions.
