Call forwarding to mobile within ringgroup not working
Discussion in '3CX Phone System - General' started by decorsign, Mar 13, 2017.
  1. decorsign
    Apr 16, 2012
    5
    Since upgrading 3cx Phone System and the softphone from V12.5 to V15 the forwarding rule for ringgroup members to mobile is not working anymore.
    This does not affects users where mobiles rings simultaniously.
    This only happens when calling from outbound.
    Internal extensions who call the forwarded extension, get passed trough to mobile, like it's supposed to.
    Any ideas on this problem?
    10,781
    286
    As far as I'm aware, calls to a ring group member will not follow the members forwarding rules, only calls direct to the extension. I'm not certain why it would have changed for you as it should not have worked in previous versions either.
  3. decorsign
    Apr 16, 2012
    5
    We found the solution and it is very easy.
    With the call forwaring rules under "Away" there was no tick before: "Accept calls from ring groups".
    We've enabled it and it works!!!
    Hope this helps others.
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi decorsing,
    I am glad to hear that you found the solution and thanks for sharing the solution :)
