Solved Call from 3CX to other Company IVR
Discussion in '3CX Phone System - General' started by Tom De Brouwer JFS, Mar 27, 2018.
Tags:
  1. Tom De Brouwer JFS
    Mar 27, 2018
    12
    Dear,
    The company I work for is momentarily testing 3CX.
    We currently have the issue that making a call with 3CX to another company with IVR, doesn’t work.
    It is not possible to choose a number in the ivr . (Example: For English press 1; For French press 2;…)
    Intern calls to our own IVR works without a problem.
    Does anyone know a solution for this matter? At first it actually did work…
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    Can not call an external number with IVR,
    Way round it, create a dummy extension and within the extension forwarding rules 'If I am busy or my phone is unregistered, forward calls to: ' forward to number.
    Within IVR point the option to this dummy extension.
    Note : You have hide the number from the company phonebook so people do not see it
    https://www.3cx.com/docs/manual/ivr-digital-receptionist/
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,313
    249
    Saqqara - not his issue.
    He is having Tone issues when he reaches the other IVR.
    Tom De Brouwer JFS - Are you using a supported VoIP Provider for your dialtone or is it an Analog Gateway?
    Tom De Brouwer JFS likes this.
  4. Tom De Brouwer JFS
    Mar 27, 2018
    12
    I'm sorry but I think you misunderstood me.
    when I dial out to another company. and that company also uses an ivr
    and I choose 1 or 2 etc nothing happens
  5. Tom De Brouwer JFS
    Mar 27, 2018
    12
    I use a SIP trunk it has worked but not anymore
  6. leejor
    10,744
    281
    I would "review" the DTMF Method set in the phone(s) you are using. There are usually several choices, including (in many cases) "auto". The set may be restricted to a type that is not compatible with your provider, and/or, the far end.
    What make/model phones do you use? Does this happen on all of them? Have you tried using a different type set, or the 3CX phone/App?
  7. Tom De Brouwer JFS
    Mar 27, 2018
    12
    I Use 3CX Cleint on windows pc and Andriod phone & iphone
    all the same problem
  8. leejor
    10,744
    281
    Here is a link to an explanation of the different types available.
    https://www.3cx.com/blog/voip-howto/dtmf-rfc2833/
    In the 3CX Android App I use (granted, it's an older one), there is an option to select the DTMF type. The other issue might be... the type of Codec you, or your provider is using. If you are set to use DTMF audio (only) and are also using a low bit-rate Codec, then you can have issues. DTMF audio may not pass properly.
    #8 leejor, Mar 27, 2018
  9. Tom De Brouwer JFS
    Mar 27, 2018
    12
    Thanks everyone
    It works now I had to change DTMF mode to in-band
    Thanks!
