Call from batch?
Discussion in '3CX Phone System - General' started by cadbrowne, Apr 8, 2017.
  1. cadbrowne
    Apr 5, 2017
    9
    I am trying to write a batch "wrapper" to call a number using the 3CX client.
    As far as I can tell, the syntax should be either:
    CallTriggerCmd.exe -cmd makecall:1234567
    or
    CallTriggerCmd.exe -call 1234567
    but neither one of these commands does ANYTHING. No error, no nothing. I might as well have typed "echo."
    What am I doing wrong?
  2. pact
    pact New Member
    Dec 16, 2009
    204
    37
    You are correct with those syntax, they should be working (And I can replicate them here fine).
    Are you running the 3CX client as the same user (ie not as elevated Administrator)?
    I assume the 3CX Client is running and is registered on the same computer you are running that command on.
    Can you tell us what version (And service pack) your 3CX instance is and what version your client is?
    (To find client version, Settings(Cogs in the bottom right) -> Advanced Settings -> About)
    And what licence level (Free/Standard/Pro/Ent) your 3cx is. (As it requires Pro for the API to work)
    #2 pact, Apr 11, 2017
  3. cadbrowne
    Apr 5, 2017
    9
    Yes, as the same user.
    Yes, it's running.
    Client is 15.0.60903.0
    3CX should be Pro, but how do I check that?
    Thanks for your help.
  4. jed
    jed New Member
    Feb 1, 2010
    145
    43
    It is working in 15.5 But be sure that you can find the CallTriggerCmd.exe
    C:\ProgramData\3CXPhone for Windows\PhoneApp>CallTriggerCmd.exe -cmd makecall:123456
    /Jesper
  5. pact
    pact New Member
    Dec 16, 2009
    204
    37
    On the main 3CX Dashboard, look on the right column under 'License', this will say what it is, but you can click on 'License' as well and it will show you the version on the next screen.
