call from External to external
Discussion in '3CX Phone System - General' started by MW_VNET, Mar 26, 2014.
  1. MW_VNET
    Mar 25, 2014
    6
    ist this possible?
    any external number to any external number
    call fired over API?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    you will have to give us a little more info about what you are trying to accomplish.
  3. MW_VNET
    Mar 25, 2014
    6
    we want to offer our web-users free phonecalls
    so they enter a phonenumber and the server
    makes the connection between the entered number and
    their own user-phonenumber
    on the api i can fire a call between internal extention and a external number
    the same but with 2 external numbers
  4. leejor
    11,117
    329
    While there may be a way around it, I would think that for security reasons, given that 3CX really wasn't designed for this, you may be out of luck. As far as I'm aware (or can remember) an outside call is placed in one of 3 ways (all calls being linked to an extension number for billing purposes).
    Normal origination, forwarded to an outside number, and dialled out though the voicemail menu( again ,of an extension).
    So I think you'd have to have the calls appear to originate from an extension number.
  5. craigreilly
    Feb 1, 2012
    3,575
    305
    So, in theory - the "Web-Users" would each have an extension forwarded to a phone number... ?
    The API would connect their EXTENSION and the outside number...
    (just asking for my own clarity)
