call from winphone cti mode not hear ring
Discussion in 'Windows' started by ags, Dec 25, 2016.
  1. ags
    ags
    Jan 8, 2013
    11
    3cx 15
    i have a cisco spa512g & winphone ( cti )
    if i call from cisco, i hear the ring
    if i call from winphone ( cti ), i not hear the ring
    in every way the call is done correctly
    with previus version 14 3cx It is working properly
    help me
    Giulio
    11,277
    360
    To clarify...you are talking about lack of ring-back (tone)? is this affecting more than one extension? Is there audio when the called party answers? Is this on external and internal calls?
  3. ags
    ags
    Jan 8, 2013
    11
    yes the problem is ring-back tone.
    yes the audio is when the caller answers
    the problem is on all extension, internal / external and only when i call through winphone ( cti )
    with winphone ( softphone ) is ok
    if I call with the cisco phone it's ok
    thanks
    #3 ags, Dec 26, 2016
  4. ags
    ags
    Jan 8, 2013
    11
    help me .....
    thanks
  5. ags
    ags
    Jan 8, 2013
    11
    in versione 14 it's ok .......................
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    With phones that have limited support like the Cisco phones, when used in CTI mode the phone will work with the MakeCall feature.
    When you start a call using “MakeCall” the desktop IP phone will be called from 3CX Phone System and on the phone’s display you will see “MakeCall”. After you pick up the handset the call will be placed on hold and a call to the destination is made from 3CX Phone System. Once the receiving end answers the call, music on hold will stop and the call will connect to the callee.
  7. ags
    ags
    Jan 8, 2013
    11
    thanks,
    at this point back on the 14 .....
    the tone ring it is necessary.
