call get disconnected,ACK error after upgrade to v8
mbulles
I upgraded my V7.1 to v8 recently.
Everything works almost fine, but after the upgrade i noticed that when making an outbound call via voip(buster.com) the call gets disconnected after 20/30 seconds. I directly place a new call everything works fine.
I think the problem is the fact that ACK is not received? How to solve this?
12:43:39.287 [CM503008]: Call(28): Call is terminated
12:43:39.279 [CM503021]: Call(28): ACK is not received
Here is my logging:
12:47:34.230 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.21:3478 over Transport 192.168.1.2:5080
12:47:34.229 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.21:3478 over Transport 192.168.1.1:5080
12:43:07.251 [CM503007]: Call(28): Device joined: sip:[email protected]:5060
12:43:07.245 [CM503007]: Call(28): Device joined: sip:[email protected]:5060
12:43:04.431 [CM505003]: Provider:[Voipbuster 31857854588] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:[email protected]:62493]
12:43:04.132 [CM503025]: Call(28): Calling VoIPline:0455792xxx@(Ln.10002@Voipbuster 31857854588)@[Dev:sip:[email protected]:5060]
12:43:02.305 [CM503004]: Call(28): Route 2: VoIPline:0455792xxx@(Ln.10003@Voipbuster 31434301xxx)@[Dev:sip:[email protected]:5060]
12:43:02.304 [CM503004]: Call(28): Route 1: VoIPline:0455792xxx@(Ln.10002@Voipbuster 31857854xxx)@[Dev:sip:[email protected]:5060]
12:43:02.279 [CM503001]: Call(28): Incoming call from Ext.105 to <sip:[email protected]>
I did not have this problem running v7.1 3CX
Get 3CX - Absolutely Free!
3CX
