Call Handling Based on Time of Day
Discussion in 'Ideas' started by TSlocum, Jan 31, 2017.
Call Handling Based on Time of Day 5 5 22votes
5/5, 22 votes
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    The in and out of office hours isn't sufficient to schedule complex routing. There should be multiple options to schedule things. For example, it would be great to be able to schedule inbound rules like so:
    00:00-05:00 IVR
    05:00-07:00 Ring Group
    07:00-17:00 Queue
    17:00-23:59 Same Ring Group
    business54 and DSXDATA like this.
  2. katy1
    Nov 2, 2016
    DSXDATA likes this.
  3. earthwing
    Sep 14, 2010
    10
    No doubt doing it using extensions does work but when you got 7 locations all running under a single hosted PBX that has many extensions setup for call routing, that sure creates a mess of sorts for someone coming behind trying to to sort out the logic and make changes. Really looking for 3CX to clean up a workaround process and allow us the flexibility at the root of the issue. This is also in line with a requested post I did yesterday
  4. eli
    eli
    Feb 25, 2012
    8
    Voted Yes
  5. Patrick Hogan10
    Nov 23, 2016
    27
    Thumbs up for this one. Great idea!
  6. solutionsit
    Nov 25, 2014
    62
    5
    take a look at asterisk. They have a module so in the case of 3cx it could be a section like ring groups.
    so the time entry could be a destination from say a ring group and have multiple outputs based on time.
  7. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    626
    105
    We have developed similar 3CX routing solutions based on time of day using the VAD. If you would like, we could look at building a routing solution for you. The only limitation as of this posting is the VAD has not been released for V15 yet. This absolutely can be done.
  8. Thomas Six
    May 31, 2017
    8
    Hi voiptoys
    Can you show me how I can make a simple VAD script that routes calls based on time of the day? For example if hour>6 go to 200 and when hour=<6 goto 201?
    Thanks in advance,
    Thomas
  9. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    Thomas Six, I got your PM.
    I haven't used VAD, but if you have a simple routing schedule such as 00:00-06:00 goes to 200, and 06:00-23:59 goes to 201, you can do that by setting office hours routing. For example, if using an inbound rule rather than global office hours, you could create an inbound rule with the DID, set destination 201 as during office hours, and 200 as outside office hours. You would then enable "Set up specific office hours for this trunk" and set 06:00-23:59 as the office hours.
    Let me know if the hours are more complicated like I originally asked, and I will explain how I accomplished that routing.
    I'm very interested in VAD, though, now that it's available, at least as a beta. I haven't had a chance to take a look.
  10. Thomas Six
    May 31, 2017
    8
    Thanks for your reply.
    We have 4 time periods each day. And the routing has to be different for each time period.
  11. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    I'm sure the VAD would be much simpler, but I have no experience with it. This is what I did to accomplish three time periods.
    1. Create a dummy extension
    2. Create an inbound rule that routes to the dummy extension both during and outside office hours
    3. Edit the dummy extension and go to the Forwarding Rules tab, and find the Exceptions section
    4. Click Add Rule
    5. Set Caller ID to *
    6. Set Received During to "Specific Hours"
    7. Set Office Hours for the time period for each day, ex. 00:00-06:00 M-F
    8. Set Forward To to the extension it should route to
    9. Click OK and then repeat steps 4-8 for each time period
    10. Click OK at the top to save all the changes
    See also https://www.3cx.com/community/threads/multiple-sets-of-office-hours.47369/#post-192332
  12. Thomas Six
    May 31, 2017
    8
    Hello
    I have found the solution. When you want to check if it is saterday or Sunday, this is the Condition: new Date().getDay() == 6 || new Date().getDay() ==0 . Sunday is 0 and saterday 6. When you want to check if it is 12 o'clock : new Date().getHours() == 12.
    For other time values: https://www.w3schools.com/js/js_date_methods.asp
    Regards,
    Thomas
  13. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    Nice find. This is in the VAD thing? I'll have to bookmark this for when I check that out.
  14. VictorSP
    Sep 6, 2016
    61
    11
    Same solution here, but I think this could be great if it's possible on Inbound Rules directly. Also calendars must be available per Inbound Rule.
  15. xantip
    Apr 24, 2012
    14
    I want to add something more. Already created the solution with the dummy extension. This works fine to hanlde incoming trunk calls during specific hours.
    But my customer has flexible end hours.
    Now they put 3CX manually in out of office mode (you can create a dial code for this, let say *64).
    *640 is automatic programmed operation
    *641 is permanently in office hours
    *642 is permanently in out of office hours
    I created 2 custom speed dials to allow the customer to switch to *640 and one to swith to *642. They never use *641.
    But there are some drawbacks:
    - no visual indication of the status of the PBX on a BLF
    - mode is permanently in or ouf of office (*641 or *642).
    I want a third option, where you put the PBX in out of office, but it should switch to the programmed office hours at the next programmed tim switch.
    In this specific case, it's a doctors cabinet and office hours are set from 8:00 until 23:59.
    When the last doctor leaves, ie. at 20:30, he pushes the BLF that sends *642 and the PBX goes in out of office, resulting in another IVR message on the main trunk.
    In the morning, they have to push the BLF that sends *640, before the office opens. As already mentioned, the call handling on the trunk is done with a dummy extension, so it's not important if they send *640 at 7:00 or 7:40 or even at 7:59. As long as it's before 8:00, it's ok.
    There should be an option 3CX switches automatically back to office hours at 8:00, let's say *643.
    This is especially important since there is no status on the BLF key, so no visual indication the PBX is in out of office.
    I also tried to program a BLF to an extension which status follows the out of office hours. But extension status like Away and DND is not reflected on the BLF's of a physical phone either, only on the softphone. Tested this with Fanvil C600 and Yealink T46.
    There is another thread about adjusting the colour of a BLF key to red when an extension is in DND or Away, https://www.3cx.com/community/threads/ability-to-see-an-extensions-dnd-status-with-blfs.43023/
    Maybe a good idea to also vote also for that one.
    Best,
    Jos
  16. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    25
  17. Silly English Kniggit
    Sep 13, 2017
    220
    81
    Yes - including for queues ring groups, and trunks. Currently we have to use virtual extns all over the place, which isn't a great option and breaks some things like call reporting.
