Call History of Redirected or Pickuped calls
Discussion in 'Ideas' started by Mike99, Aug 25, 2017.
  1. Mike99
    Aug 25, 2017
    19
    We are running 3CX ver 15.5 and noticed that when a call for extension A is picked up from extension B, the incoming call does not get registered in the call logs for the extension A.
    Would it be possible to have the extension called (in this case extensio A) be notified of the call that was picked up from extension B ?
    Thanks in advance
