Call history service take more memory
Discussion in '3CX Phone System - General' started by bluetel2, May 20, 2009.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Hello
    We have problem with one server. their is call history service which take more mémory (2go), and it's affect calls. after restarting service it's ok, but later (some days) it's the same problem.
    i have the 7.1 v, and in log of 3cx theire is nothing.
    If anybody can help me Thanks
    in the callhistory log file :
    15:03:03.086|Exc(03)| System.OutOfMemoryException: Une exception de type 'System.OutOfMemoryException' a été levée.
    à System.String.Split(Char[] separator, Int32 count, StringSplitOptions options)
    à CallHistoryUpdater.CallLogParser3.ParseLine(String ln)
    15:03:03.132|Err(01)| Extended Exception Info : : System.String[] Split(Char[], Int32, System.StringSplitOptions): 0
    : Void ParseLine(System.String): 0
    15:03:15.148|Inf(03)| --Worker thread exception
    15:03:15.179|Exc(03)| System.OutOfMemoryException: Une exception de type 'System.OutOfMemoryException' a été levée.
    à System.String.CtorCharArrayStartLength(Char[] value, Int32 startIndex, Int32 length)
    à System.IO.StreamReader.ReadLine()
    à CallHistoryUpdater.CallLogParser3.parsefile(IHistoryProcessing hist, String fname)
    à CallHistoryUpdater.CallHistoryUpdater.Run(String[] args)
    à CallHistoryService.Service1.ServiceWorkerMethod()
    ------------|Inf(00)| Date: 20/05/2009 15:23:01
    15:23:01.366|Inf(03)| 3CX Call History Service process exiting.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,559
    118
    This is a known problem, and has been fixed for the next version... If you can just keep tackling this problem till the release is out, which will be very very soon. :p
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Thank you Leonidas.
    have good day
