Call Hop Off
Discussion in '3CX Phone System - General' started by jelliott52, Nov 30, 2009.
  1. jelliott52
    Oct 21, 2009
    28
    Hi All,
    Is it possible to call another 3CX system and make a local phone call out of the system?
    Example;
    Client has 2 offices Office A and office B. It's a toll call to call office B, but the client can call office B through the 3CX bridge. But if the client at office A want's to call a customer in office B's area there is a toll charge. Can you do a hop off from office B's system and make a call to the local area?
    Thanks,
    Jay Elliott
    10,375
    231
    I'm not sure if you can dial only extensions, if two 3CX PBXs are linked (bridged). There is no option for a DISA port unfortunately.
    Callers can dial back out through options in the voicemail system when checking their VM , and a call could be routed to the DR with one of the options to go to the VM system. If a lot of calls are made in that specific "foreign" city you could install a gateway, like the SPA3102 connected to a PSTN line and datafill it as a trunk in the "local" 3CX. This requires that the 3102 is behind a fixed public IP at it's end, or the router it's behind is using a DDNS service.
    You could also try creating a trunk in the local 3CX that registers to an extension in the other switch. You'd have to play around a bit with the dialplan in both boards.
  3. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    This should be possible.
    Register a Gateway at both locations and set different dial plans to use the different gateways.
