Call-Info Header Forwarding
Discussion in '3CX Phone System - General' started by dweidig, Mar 18, 2008.
  1. dweidig
    Mar 18, 2008
    I'm trying to create a paging application for paging to LinkSys SPA941 phones. The SPA941 uses ";answer-after=0" in the Call-Info header on the Invite to auto-answer for paging applications. However, it appears that 3CX is not forwarding the Call-Info header to the destination. According to RFC 3261, the Call-Info header should not be deleted by the proxy.
    Are there any reasons that the Call-Info header would not be forwarded?
    I've included a example 3CX logs from the LinkSys SPA941 paging to an application:
    23:27:56.061|.\CallLeg.cpp(110)|Log5||CallLeg::eek:nNewCall:[CM500002]: Info on incoming INVITE:
    INVITE sip:102@192.168.2.124 SIP/2.0
    Via: SIP/2.0/UDP 192.168.2.125:5060;branch=z9hG4bK-37149fca
    Max-Forwards: 70
    Contact: "200"<sip:200@192.168.2.125:5060>
    To: "102"<sip:102@192.168.2.124>
    From: "200"<sip:200@192.168.2.124>;tag=9af5898bff92863eo0
    Call-ID: bfaf414f-732c914a@192.168.2.125
    CSeq: 102 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Call-Info: <sip:192.168.2.124>;answer-after=0
    Proxy-Authorization: Digest username="200",realm="3CXPhoneSystem",nonce="12850288075:6da63242ae70baff2530164037428ac4",uri="sip:102@192.168.2.124",algorithm=MD5,response="fca0404742094a6addae68ccbf963c71"
    User-Agent: Sipura/SPA941-4.1.8
    Content-Length: 0
    23:27:56.130|DialogUsageManager.cxx(800)|Debug8|Resip|::ResipLogger:SEND: INVITE sip:102@192.168.2.110:5070;rinstance=e73afb29d9474a38 SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d87543-ba4cfe01055b6e2a-1--d87543-;rport
    Max-Forwards: 70
    Contact: <sip:200@192.168.2.124:5060>
    To: <sip:102@192.168.2.124:5060>
    Call-ID: Nzc3MzRiNzY0M2Q1NGRlYWU0ZDhlMmUwYzVlMTViZWQ.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Content-Type: application/sdp
    User-Agent: 3CXPhoneSystem 5.0.3790.0
    Content-Length: 427
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    3CX PhoneSystem is not a SIP proxy. That is why proxy rules are not unconditionally applicable. But we're considering implementation of paging and intercom, so this ability will appear quite soon.
  3. dweidig
    Mar 18, 2008
    Thanks. Paging and intercom support would be great. If paging is implemented like in Asterisk, that would be great also. I found 3CX very easy to setup and most of my customers are Windows users, so would I really like to use 3CX for this application.
