Call is not allowed by system
Discussion in '3CX Phone System - General' started by nml, Mar 9, 2010.
  1. nml
    nml
    Oct 8, 2009
    21
    What does it mean when 3CX tells me call is not allowed by system when i dial inbound?
    For example...
    I dial in to my GXW from the PSTN. Occassionally, for no reason, 3cx will tell me "call is not allowed by system" and hang up on me, instead of going to the DR. What does this mean? What could cause it?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    The pbx is rejecting it, can be for multiple reasons. The best place to start would be to look at the the server logs, if you could paste the logs of a failing call we might be able to identify where the problem is originating from,
  3. nml
    nml
    Oct 8, 2009
    21
    I havent been able to catch it in the act yet, but here is a good incoming call. Is there anything in here out of place?
    This call comes in, then goes back out to the PSTN (this particular extension is designed to do that).
    successful call (does this look OK?):
    09:53:50.601 [CM503008]: Call(689): Call is terminated
    09:53:49.882 [CM503007]: Call(689): Device joined: sip:10008@192.168.123.11:5060;transport=udp
    09:53:49.866 [CM505002]: Gateway:[The GXW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4108 (HW 1.1, Ch:8) 1.3.1.6] PBX contact: [sip:10008@192.168.123.244:5060;transport=udp]
    09:53:48.257 [CM503008]: Call(688): Call is terminated
    09:53:47.726 [CM503025]: Call(689): Calling PSTNline:2514578@(Ln.10008@The GXW)@[Dev:sip:10008@192.168.123.11:5060;transport=udp]
    09:53:47.679 [CM503004]: Call(689): Route 2: PSTNline:2514578@(Ln.10008@The GXW)@[Dev:sip:10008@192.168.123.11:5060;transport=udp,Dev:sip:10010@192.168.123.11:5064;transport=udp,Dev:sip:10012@192.168.123.11:5068;transport=udp,Dev:sip:10013@192.168.123.11:5070;transport=udp]
    09:53:47.679 [CM503004]: Call(689): Route 1: PSTNline:2518304@(Ln.10008@The GXW)@[Dev:sip:10008@192.168.123.11:5060;transport=udp,Dev:sip:10010@192.168.123.11:5064;transport=udp,Dev:sip:10012@192.168.123.11:5068;transport=udp,Dev:sip:10013@192.168.123.11:5070;transport=udp]
    09:53:47.663 [CM505002]: Gateway:[The GXW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4108 (HW 1.1, Ch:1) 1.3.1.6] PBX contact: [sip:10009@192.168.123.244:5060;transport=udp]
    09:53:39.523 [CM503007]: Call(689): Device joined: sip:801@127.0.0.1:40600;rinstance=24ec46bc115de2f2
    09:53:39.523 [CM503007]: Call(689): Device joined: sip:10009@192.168.123.11:5062;transport=udp
    09:53:39.304 [CM503025]: Call(689): Calling Ext:Ext.801@[Dev:sip:801@127.0.0.1:40600;rinstance=24ec46bc115de2f2]
    09:53:39.288 [CM503004]: Call(689): Route 1: Ext:Ext.801@[Dev:sip:801@127.0.0.1:40600;rinstance=24ec46bc115de2f2]
    09:53:39.273 [CM505002]: Gateway:[The GXW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4108 (HW 1.1, Ch:1) 1.3.1.6] PBX contact: [sip:10009@192.168.123.244:5060;transport=udp]
    09:53:39.273 [CM503001]: Call(689): Incoming call from 2124721773@(Ln.10009@The GXW) to <sip:801@192.168.123.244:5060>
  4. tehama
    Jun 17, 2010
    7
    I have the same problem but I can replicate. If the system makes 2 outgoing call all incoming call get "call not allowed by system" and are dropped. on the Port/Trunk Status the inbound call pops up as an OUT call.
    here is log:
    16:28:58.859 [CM503019]: Call(887): Rejected! Line is 'Busy' because number of simultaneous calls per line 5305261234@(Ln.10021@GXW-4108 192.168.XXX.XXX) is limited by Administrator
  5. leejor
    11,077
    324
    I would think that this is either a licence restriction (number of concurrent calls), or, there is no outbound route for the call, all trunks busy?
  6. tehama
    Jun 17, 2010
    7
    Re: Call is not allowed by system (solved)
    Figured it out. In 3cx set Maximum Simultaneous calls on each port to 4 or 8 depending on the Grandstream model. The grandstream is sending the next call sometimes on an already open channel. This is causing 3cx to error cause the max simultaneous call was set to 1. So far problem has gone away.
  7. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Get ready for another problem...
    All outbound calls using a GXW4104-4108 no matter what port you use to send it out (10000-10003), the GXW will use it's own port not the one that 3CX pre-selected. Result 3CX send a call out on 10000, GXW instead uses FXO port 4 (would be 10003), now while on the call, a real call comes in on FXO1 and 3CX received an invite for 10000, because you specified 1 call, it will ignore it.
    The 4 concurrent calls is a temporary workaround to alleviate that issue. For now only Patton FXO work well. Known issue currently worked on.
