call keep haning in queue after agent terminate it
Discussion in '3CX Phone System - General' started by mstit, Apr 23, 2016.
  1. mstit
    Mar 22, 2016
    5
    Hi i have a lot this to calls that keeps haning in queue after i have ended it. but ussly it is arround 4 AM server time.
    it is a hosted PBX.
    any one that have problems with to...? or had simlary experience with this.
    the only way i can get out of that is to complet shut down the program and start it up after.
    i have Bullguard and MS win 10 firewall active.
  2. mstit
    Mar 22, 2016
    5
    It seam that a new Windows install solved the problem
