Call Limits Per Extension/Group
Discussion in 'Ideas' started by Werner Schulz, Dec 7, 2017.
  1. Werner Schulz
    Jul 11, 2017
    Set call limits per Extension/Group so that they can only phone a certain amount of minutes a month. Reason is as follow: In remote rural areas ( Congo/Africa ) we have gateways with SIM cards attached. These SIM cards are on a contract that only allows a certain amount of minutes per month.
