Call lists cleanup
Discussion in '3CX Phone System - General' started by cfive, Mar 29, 2010.
  1. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Does anyone know how call cleanup works, or how to configure/modify it? It seems to run periocally. Also, in the myphone web pages, I can't seem to discover a way to prune them (i.e. remove old items).
    Thanks - Les.
  2. t4mack
    Jan 19, 2010
    56
    The call logs are being stored on the server you can't delete them from the myphone web interface. You can try clearing the call logs from the call reporter on the pbx, but I'm not sure if that will work.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, you need to open the Call log Reporter and select Clear Call Logs.
    From there you select the dates From/To or if you want to remove all the calls select Clear all Logs.
