Call log doesnt work but service works
Discussion in '3CX Phone System - General' started by Volkan Celebi, Jan 4, 2018.
  1. Volkan Celebi
    Nov 20, 2017
    13
    we can't see the incoming calls in panel.
    version: 15.5.0
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @Volkan Celebi
    If you are referring to the Call Log from the Management Console, please note that calls are by default filtered for the current day. If you want to see calls for previous dates, click on Filter and change the Range.
