call log is empty
Discussion in '3CX Phone System - General' started by dnwklin, Feb 23, 2009.
  1. dnwklin
    Feb 2, 2009
    10
    I have experiencing a problems. When I use call report tools, the call log is empty. The case is the same, whether I run the call report utility on the same machine of the phone system or remotely. I tried to view the database directly, I also get a empty table. What may be the problem? Thx
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Have you followed the steps as indicated at http://www.3cx.com/support/call-history-updater.html ?
  3. dnwklin
    Feb 2, 2009
    10
    Is there a way to get a real time call logs?
  4. William400
    Aug 21, 2006
    1,005
    Realtime call logs are currently not possible.
    Further improvements to call logging shall be part of V7.1 which is soon to be released. Details of this will be part of the release notes in the coming weeks.
