Call Log Reporter not working
Discussion in '3CX Phone System - General' started by mase2hot, Jan 10, 2011.
  1. mase2hot
    Aug 17, 2010
    38
    this has stopped working, it was working ok. But now whne I selete view report it hangs. I have restarted PBX and still have the same issue. Any ideas?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Mase2hot,
    Well the best advise I could probably give you is, to take a backup uninstall and resinstall. Also make sure you have no pesky anti virus software running.
