Call Log Reporter Question
Discussion in '3CX Phone System - General' started by pjr, Sep 22, 2011.
  1. pjr
    pjr New Member
    Oct 5, 2009
    154
    We use 3CX internally for our helpdesk and are wondering if the reporting in V10 or the call center add on can provide the following info
    We need to demonstrate the time taken to answer calls made to our helpdesk in percentage terms
    eg 10% of calls are answered in under 5 seconds, 30% in under 20, and 100% in under 30 seconds
    Can the log reporter or call center log reporter deliver that report without a need for manipulation?
    Paul
