Call Log Time Incorrect
Discussion in '3CX Phone System - General' started by neville, Oct 11, 2016.
  1. neville
    neville New Member
    Apr 23, 2012
    226
    42
    Is there a way to have the time on the call log show correctly? It is 4 hours ahead. All other times are ok.
  2. norekhov
    3CX Support
    Jan 31, 2014
    53
    If you're referring to Linux version that is fixed in SP2 and (I believe) soon will be available.
  3. neville
    neville New Member
    Apr 23, 2012
    226
    42
    Thank you. This is the Linux version.
  4. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    I have the same issue, but it's in the activity log thing in the zip when you generate support info on Windows. Is this fixed as well?
  5. norekhov
    3CX Support
    Jan 31, 2014
    53
    I checkes and saw no issues there.
    Can you be more specific in what you see and what you expect to see in support info?
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    408
    10
    Hi, please update to the latest service pack.
  7. supplenta
    Oct 3, 2012
    35
    I think it would be advisable to post the release notes for SP2 before releasing SP2!
    When are you posting the info?
  8. datamerge
    datamerge New Member
    Nov 19, 2014
    181
    25
    I can confirm it is fixed in SP2. :)
  9. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    408
    10
    Thanks for the feedback.
  10. AHAutomation
    Mar 31, 2016
    31
    We have the same issue, only on Windows.
    The time in the log files is 2 hours behind.
    All other times are correct, even the time in Call Log on the 3cx console.
    We use version 15.0.62928.5, no updates are available.
  11. icolas
    Apr 18, 2017
    5
    We have 3cx hosted version on OVH.
    Same issue, also for office hours is this a problem, I need to set them 2 hours back. Our my clients reach out of office voicemail. (even I've set timezone correct (Brussels +1)
    we have 3cx Latest version
  12. AHAutomation
    Mar 31, 2016
    31
    The logs are saved in this location: "C:\ProgramData\3CX\Instance1\Data\Logs\CDRLogs"
