Solved Call Log
Discussion in '3CX Phone System - General' started by Flash99, Aug 24, 2017.
  1. Flash99
    Aug 3, 2017
    83
    7
    I have 3CX PRO Edition
    When I go to Call Log section I see only very recent calls there
    I know that the free edition removes call logs, but why I don't see them in the Pro edition ? Is there a place where I can set for how long to keep the logs ?
  2. AndreasPo_3CX
    AndreasPo_3CX Support Team
    Aug 10, 2017
    138
    12
    Hi @Flash99 ,
    when in the Call Log menu, click on "Filter" and make sure that "Range" is set to 90 days. That is the maximum you can display in the Call Log, if you need more than that you will have to generate a call report.
    Hope this helps.
  3. Flash99
    Aug 3, 2017
    83
    7
    I knew its something simple :)
