Call Log
Discussion in '3CX Phone System - General' started by ansu2723, Apr 22, 2009.
  1. ansu2723
    Nov 23, 2008
    29
    Why?
    In the latest version 3cx have changed the teqnique how they write to the call log. Before they wrote to the log instantly. Now it takes a couple of seconds after the call has ended.
    We used the log to let our callcenter application tell us that it was an incoming call and it looked in our database who had that number.
    Anyone who can help me find out an other tequniqe to get all information about the call instantly when it happends?
    I dont like when they make changes like this. This puts our system upside down.
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I'm using v 7.0
    without delay
    what is your version
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    I have the same issue
    it's very big problem for me
    because I take CID from it before answer
    I hope that does not go on like this
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,889
    190
    You have to use documented APIs.
    If you want to get a notification upon receiving a call, you can use the CRM API.
    If you are digging around in the database directly, then for sure you will have problems when new versions are released. Again, use the documented API
  5. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello Nick Galea,
    Thank you
    I wonder Why not be as it was
    I hope to return as it was
    Because my software are dos software
    so I can only read from txt file
    Thank You Again
    Best Regards
    Galal Hazem
