Call logging in v14
Discussion in '3CX Phone System - General' started by richard.wilson, Oct 8, 2015.
  1. richard.wilson
    Oct 7, 2015
    Hi, I've been trying to figure out how to extract some call stats from v14 but the CDR tab is missing from the Settings>Advanced area and I'm not sure how to enable CDR logging otherwise. I would be happy with simple text file logging as I can then read this into a database and query as necessary. The CDRTemplate-Single.xml file exists and is set as necessary (left as default) but no file (calls.txt) is being created. Please let me know what I'm missing or if this feature has been removed in v14. If so, what other options have I got for capturing call data as we need something like the Wallboard which has also been removed? Thanks for any help.
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    182
    15
    CDR/Wallboard have been removed. Said to be added back in a service pack before the end of the year.
    http://www.3cx.com/forums/v14-changes-41960.html
  3. richard.wilson
    Oct 7, 2015
    So am I right in thinking that there are no mechanisms at all for live call stats in v14? No CDR/SMDR, no Wallboard, no web stats, no access to the database, no logging to a simple text file, nothing? This seems to be a pretty fundamental missing element. We have live call stats on a screen for our telesales team which I need to be able to replicate. Any help on how to view live stats in v14 would be much appreciated.
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    As 3CXuser already said, CDR has been implemented as a web API in SP2, so then you will be able to use that.
