Call Logs - calls missing
Discussion in '3CX Phone System - General' started by olt, Nov 1, 2017.
  1. olt
    olt
    Nov 16, 2012
    10
    We're noticing that calls that some calls are missing from the logs. Specifically, it seem that calls which were transferred from one extension to the others, don't show up in the call logs on the client or server.
    Has anyone else seen the same? Is this a known issue or 'feature'?
    Thanks,
    Edmund
    Running 15.5.5 with Windows 3cx Client
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,372
    278
    Hello @olt
    Can you provide an example of a call flow that results to a missing call? Are these local calls or external calls?
  3. olt
    olt
    Nov 16, 2012
    10
    External call comes in to ringing group.
    Call picked up by extension 200 - this shows in call log
    Attended transfer to extension 201 - this shows in call log
    External call connected to extension 201 - this does NOT show in the log.
  4. YiannisH_3CX
    May 10, 2016
    4,372
    278
    What happens if you run a call report? does the call appear in there? Can you tell me the exact PBX build you are running? You can find this on the Dashboard next to the licence tab
