Call Logs
Discussion in '3CX Phone System - General' started by colin2710, Jan 28, 2008.
  1. colin2710
    Oct 29, 2007
    28
    Hi there,
    I see in 3CX you can view/print/download the call logs, but is it possable to get the raw logs?
    Regards - Colin
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    If your SQL skills are good enough you can get em out of the database.
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    System Logs or Call History?
    For system logs you can visit your \<3cxinstall-dir>\Data\Logs
    For call history you can query it from DB as it has been suggested above.
