Call monitoring
Discussion in '3CX Phone System - General' started by manistopit, Aug 22, 2009.
  1. manistopit
    Feb 18, 2009
    26
    Please tell me if 3CX support call monitoring feature
    Can we listen the live call of any extention
    Kindly advice
    Regards
    Manistopit
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Yes, this feature is supported in the commercial versions of 3CX version 8.
  3. manistopit
    Feb 18, 2009
    26
    Are you sure its working properly in new version
    Have you used it
    Thank you
  4. comresource
    comresource Member
    May 22, 2009
    303
    I have tested with it and yes it works. You have to initiate it from the Call Assistant.
