Call Monitoring
Discussion in '3CX Phone System - General' started by daktur, Mar 15, 2016.
  1. daktur
    daktur New Member
    Oct 15, 2015
    227
    8
    Hi All!
    Is there a way to monitor a call of an extension? To hear de call on time while the agent is talking instead of downloading the record?
    Thanks a lot for the help!
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
    There is a "Listen In" function that you could use through the 3CXPhone for Windows. In the following link there are instructions how to enable it:
    http://www.3cx.com/docs/extension-management/#h.49ir3mjinqz3
    Once enabled for an extension, if you open the expanded presence screen you should be able to right-click on an active call and listen in on it.
