call not connecting
Discussion in '3CX Phone System - General' started by trevor.austin, Feb 7, 2010.
  1. trevor.austin
    Feb 7, 2010
    I have got this setup and it sort of works. However when I answer the incoming call all I can hear is a continuous beeping sound, almost like an engaged tone. This is the same whether the call is inbound or outbound. Both ring fine but no actuall connection. Any ideas please. The two sip lines I have connected and the extension to extension are fine.
  2. trevor.austin
    Feb 7, 2010
    Small update. Rebooted the server this lives on (vsphere virtual server) and now the calls connect but no sound either end. Call held until deliberate disconnection but no sound at all.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Do you have sound drivers and microphone?
    Skype needs proper sound drivers to work. If you install skype on a machine without sound drivers and microphone, skype does not work. 3CX Skype Gateway needs skype to work. Without sound drivers skype gateway will connect but audio will not pass or have jittering sound. Also if you want you can make this test. Install skype on your virtual server machine and call another skype user and see the results.
    Thanks and regards.
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    68
    Hi, Trevor
    Did you tried to call from an extension Skype's sound service, echo123? It's first recommended - and very useful - test to do.
    Regards
    vali
