Call on HOLD beeping
Discussion in '3CX Phone System - General' started by isma, Aug 23, 2012.
  1. isma
    Nov 3, 2009
    13
    Hi my client just ask me a good question.
    He would like to have a "beep" sound when we as calls on hold to remind hom he has some.
    His old system had that function and he would like to have it back.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    You'll have to tell us what phones you are using. There is likely a setting in the template to enable this.
